Indicates that a tech support report was successfully sent to the indicated collector. collector: Hostname or IP address of a tech support collector port: TCP port number that the collector is listening dataset: Data set configured for the collector sslmode: Whether SSL is enabled or disabled when connecting to the collector
No action required - Informational message only.
Info
Sent a %dataset% tech support report successfully to the collector %collector%:%port% with SSL %sslmode%
| Name | Type |
| collector | String |
| port | uInt32 |
| dataset | String |
| sslmode | String |
